vanrj1
My Vacuum is running about 12hg in my poly 318 with a 264/450 cam. I think normal stock runs 17hg or so correct?
Would 12hg be right for this more aggressive cam? initial Timing is 12° with "ready run" distributor using vac advance but can use mechanical if desired. Any input appreciated.
It also has power brakes in case that matters and also was in park not in gear.
Thais is a fresh build (500 miles on it) that runs great, just not sure if Vacuum is desirable?
