Sounds like the burner control failed.
Flame sensor...
Did you pull it out, use some glass cleaner on it and put it back in?nothing..... no motor, no nothing
It didn't energize the pump. That occurs before checking for light so it's almost certainly the burner control.Did you pull it out, use some glass cleaner on it and put it back in?
AKA Fire eye. I had one fail,it was a seven dollar part back then. I changed it myself. Same symptoms you are having.Flame sensor...
What, he says it lights and then went out....It didn't energize the pump. That occurs before checking for light so it's almost certainly the burner control.
Get a fire eye too,save yourself a return trip to the burner parts store!yes
yes......this is where I am...... I'll pick one up in the morning
When the fire eye went on mine it would only reset a few times,then it wouldn't do anything at all.that was before...... things got progressively worse lol, I pulled things apart checking connections......put it back together, did the reset thing and the light stopped flashing like it should........ but now the controller just hums a little; but nothing else happens
Well ya really fawked that up didn't ya! Generally it's something stupid... you did turn up the thermostat again after playing?! Wire marret that you lost a wire on?that was before...... things got progressively worse lol, I pulled things apart checking connections......put it back together, did the reset thing and the light stopped flashing like it should........ but now the controller just hums a little; but nothing else happens
