I've been helping a friend try to get his restored Hemi Road Runner up and running. The Hemi was rebuilt and dyno tested and is stock except for a hydraulic roller cam, MSD distributor and the usual piston substitution for a clean up bore. Started it for the first time last week and seemed to be fine but had some fuel line leaks so just ran it maybe two minutes or so. Started it up yesterday to verify leaks were fixed and it seemed to start OK at first but as I was standing over the engine holding the throttle to keep it running it seemed to start loading up and I was having to hold quite a bit of throttle to keep it running about 1000 - 1200 rpm and every time I would relax the throttle it would start to die. Then smoke began pouring out both exhausts and filled the garage with smoke and it was running rough but not making any bad noises. Finally the smoke was just ridiculous and we let it shut down and I noticed a small pool of oil under the driver side. When I crawled under it there was oil dripping out of the driver side exhaust manifold and pipe connection. You could see where some droplets had been sprayed around the surrounding area. We searched and searched and found absolutely no sign of oil leaking above or anywhere else on the engine - definitely coming out of the engine in the exhaust. Unless he did so after I left we didn't have time to pull the plugs and it has PBs so that apparently means pulling the valve cover to get the rear one out.
Any thoughts? Considering the car only ran for maybe 5 minutes this was apparently a lot of oil through the engine and out the exhaust. But possibly it could have leaked into a cylinder(s) after the last start. The small puddle on the ground under the exhaust connection was about 5 inches diameter but I suspect a good deal of the exhaust innards are coated now. An intake gasket leaking from the crankcase was about the only thing I could think of that would pass that much oil that fast. But I guess valves, seals, etc are other options. I think he's a member on here but I don't think he or his wife post too often. Probably next Sat before he gets a chance to do any digging around in it except to talk with the builder.
