Could be a porous casting or a crack. I'd take it off and pull the top and pour gas into each bowl. In won't take but a few seconds to show up if there a problem.
Several of us voiced the same thing although we couldn't see anything obvious. I'll suggest that he asks our mechanic buddy to dry the bottom off real well and experiment with what you are suggesting. Also, the transition port on these comes in right above the throttle blades and I wonder if a plugged air bleed could allow it to syphon fuel out after shut down and run fuel under the blade over to the shaft and down into the intake? Maybe since it's way down at the butterfly we just weren't seeing it.
