Want to pin point the leak? Block the breather (s). Take a air supply and turn it down until you can block it off with you thumb. Introduce the air in at the PCV port. The oil will trickle out at the leak area. Quick and easy. Found more than a few very small leaks this way.
Doug
Doug
