- 2:38 AM
- Apr 13, 2012
- Granite Bay CA
I agree. If you're out hammering an engine with only 3 quarts of oil moving around then...yeah, you may encounter a dry pan.
Pontiac Fiero models with the Iron Duke 4 cylinder were fitted with a 3 quart oil pan. These engines were known to overheat and catch fire because of that. Owners may be out and about.....the engine uses a bit of oil and the owner doesn't know, the oil level drops to a point where even under normal operation, there just isn't enough oil to lubricate and cool even a small 4 cylinder engine and....BOOM.
