mopar367
I have a camshaft that I am going to use for my 446 build. Its the Purple cam # P4286677. .455/.455 lift 231 duration at 50 intake and exhaust. the engine is going into a 3800lb truck. The motor is basically a stock rebuild with a steel crank and silvolite flattop pistons. 440 source I beam rods. and 346 iron heads. Is anyone running this cam in a similar engine setup? what kind of power does it make? What cfm carb would be good on a motor like this?
