Im gonna start a build for my Fury soon. Gonna be building a mild compression stroker.. With future plans of adding a single turbo, or Procharger setup. Just curious as to what you guys think about all the stroker kits on the market. Ive heard alot of people talk trash about the 440 source cranks, right know im leaning towards the Hughes engines kit..
http://www.hughesengines.com/Index/products.php?partid=24497
Any opinions or experience would help. Thanks
If you plan on using them {Hughes} check out them on the Google search "Huges Engine Complaints" there's some
alleged complaints,
alleged in customer service & quality,
alleged inferior parts the past few years,
alleged bad attitude...
I would highly suggest, Just do your due diligence & research 1st... There are some supposedly better & way more expensive stroker cranks & kits out there, that aren't always worth the extra $$$ either... Just don't go cheap on the rods & pistons... 4340 Forging or Billet is still 4340 whom ever it comes from, the machine work is what's critical... What's your budget ?? what's your time frame ?? what's your expectations ??... If you go with a low deck/B block, you will need the mains cut to B specs & counterweights {7.2" max diameter, 7.125" is better & lighter} reduced/machined/ground to the proper sizes... By the way, I've had great success with some
440source stuff... I had a 4.15" 100% USA Made Platinum stroker kit in my last car, it lasted 7+ years running a limited schedule & running well into the 9's {with an occasional 300 shot blast of N20, well into the 8's} before I sold the car 4+ years ago & it's still racing today...
440source also have some
100% USA Made stuff too, not all their parts is/are imported, there are some real hatters out there, spreading lies... For the most part, the foreign/Chinese cast Stealth Heads are their biggest selling imports... IMHFO you have to check anything you buy, no matter who it comes from any more, there's way too many horror stories, out there when buying parts today... I hope you know a good & reputable automotive machinist, you will need one... There are people that have issues even from the more reputable 100% USA Made guys too.... You can't believe everything you read on the WWW either, people have an agenda of their own, sometimes too... A
block girdle is a really good idea too,
quality studs & hardware everywhere is also a must, especially with any boosted, N20, Turbo or Blown engine combo, if you plan on running it hard "ever".... Mancini Racing, Ohio Crankshaft, Ray Barton, 440source, Indy, MRL,
among many others out there... A
Callies Billet 4.25" Hemi Crank, is what I use to run years ago, made for running heavy boost, in both a 10:71 Blown Max Wedge or 12:71 Blown Milodon Mastodon Hemi, both on Alky, in my old 23 Altered & they ain't cheap either, the crank alone is twice the cost of a
440source complete kit... How fast do you want to go ?? How much can you spend ?? How high will you spin the engine ?? How much boost are you thinking of running ?? How heavy is the car ?? What kind of trans will be behind it ?? all these questions & many, many more need to be addressed, long before you buy...
