dieseldazzle
Congrads on your build!!
Here's something I didn't know that may help you.
Demon carbs are wet flow rated, VS other carbs that are dry flow rated. Basically, that 850 Demon, is about the same specs as a 950 Holley. There are downleg boosters, and annular boosters that affect total airflow, but bottom line is they flow more.
I had an old 750 Holley on my 440, with a 509 cam , performer RPM intake, headers etc.
The 750 needed a lot of work, I felt it would pick up more top end with an 850, so I bought a Mighty Demon annular booster carb.
The new carb was lazy to drive around, it was over-carbed. The right choice should have been an 850 Holley, or a 750 Demon.
I have a new 526 stroker now, with ported Trick Flows, that carb now has great response.
I'd stick with a smaller carb on your build, it would be a better mannered ride.
Good luck on the new bullet, another FYI, Amazon has Comp Cams break in oil, 60 bucks for 12 quarts. I needed that much for my big pan, you might be able to find a 6 quart deal.
Shocked your 526 trickflow headed stroker isn't begging for more carb.
My 512 trickflow headed stroker is using 950 and I'm worried about that.
