hi group I want to know if radiator support is causing to overheat it looks like my GTX came with a 22 inch radiator it has a 26 inch radiator it when I bought it I checked it today it has 3 inches on the right side and one inch on the left side covering the radiator it's off center because of the battery box. I see somebody else cut the radiator support cutoff wheel like I said it's been overheat since I owned it for four years last four years it's been running about 200-to 210° in this year after making so many changes in the running to 240° plus. Also I can see the guys point about coolant system in the engine being clogged it been 16 years since it been a part. Also somebody wanted know at the engine was ever a part. I found receipts for the engine more parts and machine work done 8/97 for about $2000 but I'm not positive this was the last machine work done or a different engine was put in since then. The guy I bought it from the original owner it has supposedly 26,000 original miles. But he told me most of the miles were from the drag strip. But the guy I had bought it from didn't seem to know much about cars. I still think electric fans that came with the radiator are junk I've been looking at two different electric fans from Summit's I would like to know what you guys think of these two fans and also what you think about cutting the radiator frame. Here are the specifications on these two fans.
Perma-Cool Standard Electric Fans 19122 from Summit $81.92 Electric Fan, Single, 12 in. Diameter, Reversible, 2,300 cfm, Black, Plastic, Kit Amp Draw: 6.00 amps Maximum Fan RPM: 3,000 rpm
Be Cool 75080 - Be Cool Electric Fans $107.96
Maximum Fan CFM: 1,230 cfm
Fan Quantity: Single
Fan Diameter (in): 12.000 in.
Height (in): 12.000 in.
Width (in): 12.000 in.
Thickness (in): 2.480 in.
Number of Blades: 10 blades
Amp Draw: 11.80 amps
Puller Style
