66Satellite47
That sure seems like a big cam / lots of duration for a 10.5 cr. It would be interesting to know the cranking pressure of it. Wonder how well it performed.
Who's combo are you referencing? 2quick's? B-1's will produce a much high effective CR than the 10.5 TRW rating would indicate. More like 12.0 with the small B-1 chambers. If you were referring to the setup I have described above, it's a true 10.5 w/ 86 cc chambers. It is a big old cam that I had sitting around. Cranking pressure is 140 psi. My cam is not ideal, but I was looking for more top end at the strip than I was getting with my Comp XS 274S which has much shorter duration. The short duration cam did have more low RPM torque.
