I'll double check but the other end seems to short to go through the k frameUhh, looks like you have that on the wrong end. A better pic of the threaded would help as the fine thread goes into the lca and the course thread thru the k frame.
Will do I'll be back in the garage in 15Post a pic and also measure the shaft diameter and washer id.
Bushing fits fine, just the washer won't fitHow does the rubber bushing fit?
Aftermarket strut rods from mancini, machined thicker so they don't use the sleeve. Getting the File out now see what happensYou have 4 washers do 2 of them fit? I believe the wash that goes on outside MAY hit the shoulder and stop you from over compressing the rubber bushing? My 66 service manual shows a sleeve in the center of rubber bushing to limit compression. I could be wrong.
Thought that might be the case. But what stops the bushing from being over compressed.? Did you check if 2 of the washers fit?
If two fit they would go on first then bushing then the 2 that would lock on shoulder on strut. Well good luck!Thought that might be the case. But what stops the bushing from being over compressed.? Did you check if 2 of the washers fit?
My service manual shows the same, spoke with tech at Mancini They said use moog bushing with no sleeve. None of the washers fit on the shaft
That's what I'll do, thank youI'd file 2 washers and work from there. That bushing was there to stop compression IMO.
