If you’re referring to drag race tuning, yes they tell a story if you know how to read. If there’s a lot of varying conditions driving on them you won’t get much from them, especially with the USA pump fuels and the black sludge left from additives. E85 or race fuel tuning is a whole other chapter as well. Those fuels all run different AFRs and each will tolerate different timing.
I agree on that.
But when starting on dialing in an engine from fresh (carb/ignition) you would (at least I would) start with a new set of plugs.
After some dialing in and test driving you will get some feedback of them about the combustion process, being rich or lean is easy to spot.
And if, lets say your carb is jetted too big, you will mostly run rich, which will be visible on the plugs. Same for the idle mixture.
All i am saying is that when advancing the timing, the fueling ratio must be in the ballpark fueling wise to benefit from it.
As we know, a rich mixture burns fast, lighting it up too early causes the peak cylinder pressure to be too early and the engine is fighting itself.
Regarding the fueling, i think we are more lucky with that in Europe compared to the US.
Our pumps provide RON95 (E10) as minimum and still a lot of petrol stations have RON98 (E5), I always use the E5.
And i always use an additive (Millers) that boosts the octane (they advertise 2 points but you can't know for sure), and it helps to avoid issues with the bio fuel which is my main reason to use it.
(The E10 will have up to 10% bio fuel and the E5 up to 5% bio fuel)
Wietse.
'Checking plugs', post #192.
Yes? You said that in reaction on my post.
