It only takes 50 milliamps (.05 amps) of electrical current to kill a human being.
As they say, it ain't the volts but the amps that gitcha...be careful!
One of several parameters of the Electrical Safety Tests I do on medical and lab equipment is test for "
chassis current" which is the amount of electrical current running through a device's chassis when it is plugged in and powered up,
and made operational. Some devices have the same electrical properties under power on at rest and in operation, while some exhibit a spike in chassis current from overcoming the inertia or the mechanical resistance of whatever a pump or motor is moving, and then it drops off to a steady state.
The maximum chassis current allowed to pass the test is 300 micro amps in a wet environment or 500 dry.
The other main factor is
ground resistance, which is the measurement in Ohms of the resistance
from any external metal part of the device OR from the test point (metal post) both of which should have the same ground as they are physically connected to the ground prong of the plug end of the power cord. The max resistance is .50 or 1/2 Ohm. The purpose of assuring that this low resistance is present is in the event of some electrical failure or other event, or just through normal operation of the device, that any "stray" current that develops travels through the ground wire into the grounding system of the wiring in the building, and NOT travel through a person, people, or object(s) that device may be in contact with.
Just one of many examples why electrical safety is so important, especially where medical equipment in the environment of care is concerned. The following 50 second clip demonstrates 2 common uses of an ESU (Electro Surgical Unit) or "Lightning in a Box" as I call them. ESUs are in just about every procedure room of every surgical facility I've been in, and dentists use them too:
So it's easy to understand how horribly it could go if there is an electrical safety issue with ANY medical equipment when you have an ESU generating so much current it literally cuts and cauterizes meat, the procedure table is stainless steel, there are usually 2 to 5 medical personnel in a surgery case, and saline IV fluid present, that sometimes winds up on the floor. Blood often winds up on the floor, and that too is an excellent conductor of electricity.
