Post your 11 second combos
New best pass on a 275 60r 15 pro drag radial.
Haven’t updated in a while. 10:1 451. Factory manifolds. Little solid flat tappet. 800 Eddy. 3000 PTC. 3.91 sure grip. G70-14 redlines. Should improve a bit more the next 3 weekends. I’ll update if it happens.
Bill
Tell us about your suspension setup. That's killer with those small tires!
Is this a F.A.S.T. car?
Great job! Love the stock appearing cars like this. I think I see a wrinkle in that redline!
front uses QA1 double adjustable and /6 bars and the rear is untouched from when I bought the car in 1986.
I race in both the SuperCar Shootout and fast
Good to know. Where does your front end sit at static and your shock setting if you'll share.
the front sits pretty low at rest as the /6 bars are old (nearly fully adjusted up). Shock settings Change depending on track conditions. More grip means fore tighter extension.
Lots of nice cars here but don't anyone run the 426 hemis in this 11 second category?
are they all prima donnas?
have not seen one...?
1964 Plymouth Savoy four door. 451 cid, Holley Dominator intake, .509 MP cam, 950 Vacuum secondary Quick Fuel carb, Coan converter, 4.10 gear, HD Springs (wagon), 2.75 60 R15 drag radials.
Best ET to date: 11.84 @111
full 3 inch exhaust too.
check the 9 & 10 second threads.... they tend to hang out in the deep water.:lol:[/QUOTE]
:thumbsup::D
