Propwash
- 7:21 PM
- Oct 29, 2009
- Island of Misfit Toys
excuse me for changing the direction of this thread. My question is;....Is there any reason, besides the 'ole but it's not MOPAR! crowd, that a guy could not just go out to his local wrecking yard and get a complete power disc brake setup from a modern MOPAR car, or any car for that matter, and apply this to his restomod?
I'm sure you could and people have, but like themechanic mentioned you'll be making mod's and spending money anyways. Better off going the aftermarket route if swaying away from factory stuff. At least then you'd end up with stuff that bolt's up (most of the time). Piecing together systems from other cars you'd have to start thinking about: correct pedal travel, correct alignment of equipment and bolt up, correct power assist (too much, too little, just enough), correct bore and volume for current brake system, correct piston forward & back movement, correct booster to master piston pre-gap, correct proportioning front to rear. I'm sure there's set-up's out there that bolt in or close to it, with not a whole lot of effort. Wouldn't be too much researching to find someone or a few that pieced something together that worked. Myself I'd rather have something that was engineered and proven for my ride. Or like mentioned, an upgrade like the Wilwood, Baer, SBBC ect..ect.. stuff.
