2quick
So my 66 satellite has had a steering box "Drip" for a few months now and i decided to change the seal. I pulled the dust shield, took down the snap ring, pulled the metal washer and dug out the old seal. A real PITA to say the least. While installing the new seal I didn't have a socket or pipe that would fit over the shaft and inside the opening in the gear box at the same time so i tapped it in with the blade of the screw driver. I replaced the washer, a new snap ring, and dust seal, installed pitman arm and started the car. Well of coarse it was leaking worse than before cause thats just my luck. So I chalked it up to
either a bad seal or maybe the screw driver I used to install the seal may have tore it or something. A week later I ordered a another new seal kit and tried again, this time I pulled the pitman arm, dust shield, and snap ring and started the car. (I read some ware on this forum that the hydraulic pressure from the fluid would pop the seal out). wouldn't ya know it actually works. Well again with the new seal but this time i made sure to put some sealant around the OD of the seal (it's metal with no rubber) and press it in with a nylon sleeve I had made in the machine shop. After Putting everything back together I started the car and it still leaks.
What should I do know? :banghead:
