- 6:19 PM
- May 14, 2011
- On the Ridge, TN
Oops, my bad. I thought the title of this thread was a call to arms....
Dave Hughes can be a real prick. He has zero customer service skills. Very surprising since it's his business.I'm starting to notice a trend, people are being absolute pricks for no reason!
A few weeks ago I was doing an aftermarket stereo install in my boys 2014 Charger and called a local audio shop to purchase a stereo plug/pigtail. He asks for the make, model and year then tells me I need this complete $500 install kit? I reminded him that I only asked for the pigtail and started to explain what I was doing.. he stays "good luck with that". That's it, end of conversation?
Today I call Hughes engines, I'm considering some upgrades to the daughters 5.9 magnum and they seem to be a good source for both parts and info. I introduced myself and said I'm putting a 5.9 magnum in a 1972 Satellite.. and was immediately cut off "I don't care about the car, what motor are we talking about" WTF? So I say 2000 5.9 magnum.... "O.K. I need you to read this article, decide what your goals are then call me back".. O.K? I read the article, it's explaining the ECU! I call back, told him my goal so he now tells me to go through their dyno results and find one that matches my goals to which I say " I already did and there isn't one".
If he would have shut up for 1 minute at the start of the first call he would have gotten everything he needed but could not restrain himself from being an obnoxious prick. I'm out, first impressions are everything.
Do you have a pic of the connector some of them a a MOLEX mini Jnr you can get from Mouser ElectronicsI'm starting to notice a trend, people are being absolute pricks for no reason!
The American accent?
A very well put together response.Me and a friend were talking about a local scrap/salvage guy, my friend found him difficult, and I found him reasonable, but you need to prove your reasons, my friend said "a broken clock is still right twice a day" On the flip side of that, the friendliest, most "professional" person might get a call that interrupts their flow, and they aren't their usual customer service self. These displays of humanity are a good thing, no big corporate conglomerate would tolerate such emotion, there may be one or more person you could complain to in a big company, more bureaucracy funded by the immense markup of offshore labour/parts. Smaller companies, that are good, are usually busy, and even the best people person on the phone can be taken as rude or short, meanwhile they took you call waiting while on hold with a supplier, and someone is at the counter, their 10am coffee is cold, texts from their spouse are overdue for reply, 12:20 pm and that sandwich would be have been nice at noon. Sometimes lack of courtesy is mistaken for shortness of breath. I run my own small auto shop where I do it all, answer phones, paperwork, sweep the floor, repair the car. I forget to look into some inquiries sometimes or dismiss planning complex jobs when I'm busy.
I wouldn't get turned off by one interaction, they probably have more work than than they can do, and you aren't employing their people skills. They have to sift through a lot of BS phone calls I bet. Persistence shows serious interest. Old car guys are stubborn
I have not installed an aftermarket radio in years. The main reason is called CAN networks. all the modules in your car talk to each other over this network, has to do with diagnostics and modules exchanging information. Every module in your car including the radio is a node on the network, eliminate a node and the network may no longer function. If the network goes down all kinds of problems occur. That is the reason for the high cost of the installation kits many times. Even if you buy a used OEM radio many times there is programming that needs to be done on radio replacement, only available with a OEM type scan tool usually from a dealer. Sucks but that is the way it is.The Charger is an incredible weird deal and yes I first went to Crutchfield and others. The factory stereo has wiring routed through it that ties into the heater, vehicle info screen, etc. The installation kit for it includes new heater controls plus a harness but mounts the screen down in front of the shifter which I wasn't digging.
Yes and that's exactly where I ran into problems, fortunately the factory stereo is tucked away to where leaving it in place isn't a problem.I have not installed an aftermarket radio in years. The main reason is called CAN networks. all the modules in your car talk to each other over this network, has to do with diagnostics and modules exchanging information. Every module in your car including the radio is a node on the network, eliminate a node and the network may no longer function. If the network goes down all kinds of problems occur. That is the reason for the high cost of the installation kits many times. Even if you buy a used OEM radio many times there is programming that needs to be done on radio replacement, only available with a OEM type scan tool usually from a dealer. Sucks but that is the way it is.
No but that project is done thank goodness!Do you have a pic of the connector some of them a a MOLEX mini Jnr you can get from Mouser Electronics
They are local to meYou might try Kammer & Kammer out of Ohio for the 5.9 Magnum. I got heads, cam, and intake from them for my 2001 Dakota RT. It was a while back, but they were a pleasure to deal with.
As I said, some people you can tell are just a**holes and some are just busy with their head flying in all directions. It doesn't take long to determine the difference. One person running around or one standing with his arms crossed watching you come in like you have herpes. I'm no better than anyone, but don't ever think you're better than me. I spoke with a repair company yesterday and it took two calls calles to get to her. She said she was very busy. We joked and talked for five minutes or so. I set up my appointment with her and got an email a little later confirming my appointment and thanking me for the enjoyable conversation. She said it helped her come down and level off. You can make or break someone's day, just like they can you. The art of the deal..............Me and a friend were talking about a local scrap/salvage guy, my friend found him difficult, and I found him reasonable, but you need to prove your reasons, my friend said "a broken clock is still right twice a day" On the flip side of that, the friendliest, most "professional" person might get a call that interrupts their flow, and they aren't their usual customer service self. These displays of humanity are a good thing, no big corporate conglomerate would tolerate such emotion, there may be one or more person you could complain to in a big company, more bureaucracy funded by the immense markup of offshore labour/parts. Smaller companies, that are good, are usually busy, and even the best people person on the phone can be taken as rude or short, meanwhile they took you call waiting while on hold with a supplier, and someone is at the counter, their 10am coffee is cold, texts from their spouse are overdue for reply, 12:20 pm and that sandwich would be have been nice at noon. Sometimes lack of courtesy is mistaken for shortness of breath. I run my own small auto shop where I do it all, answer phones, paperwork, sweep the floor, repair the car. I forget to look into some inquiries sometimes or dismiss planning complex jobs when I'm busy.
love the colorLike my Wife walking into our local Dodge dealer to drop 55 grand and nobody would give her the time of day, other than one guy that finally asked her what she wanted after 20 minutes that wouldn't take her seriously when she wanted to order her Challenger AWD fresh off the assembly line.
She went 40 minutes East to another dealer, was dealt with professionally there and got the first car off the line for Canada on St. Patrick's Day 2017. She drove it straight to the Midland dealer, drove up to their front window and honked the horn. The guy that wouldn't do her order came out, she put down the passenger window and told him to kiss her ***!
Green Go... it's her Winter car, easy to find in a snow bank !love the color
