PRIMERS
72satteldog
9:21 AM
minnesota
So after getting my 72 epoxied and polyester primed block and sanded and to the point of final primer and sealer...what's a quality primer n sealer before paint? I was looking PPG Omni but any advice would be greatly appreciated....we'll talk paint after priming and sealing..lol
If you are laying down a couple wet coats to come back and wet sand with 400 ect. We used ppg 3055 then after clean up at full wet coat of ppg 3025 sealer or Dp 50 or 90 depending on your color.
You should be sticking with a single brand. If you're painting this thing in your driveway, Omni is "good enough"
I do Omni primers and PPG (Deltron) base and clear. My jobber said they are certainly compatible. No problems here.
I have used the Omni for years and love it. As expensive as this **** is these days why dump allot of money into a material that mostly ends up blocked off on to the floor.
Omni is popular, but it's a production grade line of paint. Staying with one brand is a good choice.
A paint job is no place to cut corners. Omni ain't that great, but it ain't that bad. Depends on how long you are keeping it and where you are keeping it.
