'52/340...I need some guidance on sorting out the pile of parts I have, in the quest to build a 440 for my project 67 Coronet. What I have on hand for parts are two 440 engines. One is a 1973 car engine, .030 over, .010 under on the journals, forged crank, "346" heads, wiped Crane cam due to stuck lifter, flat top L2266 TRW pistons and LY rods, and one bore that has been hand cross hatched by a gorilla and has deep scoring.. The other is a bone stock 1974 MH motor with a double chain, figure 8 cooling, sewer drain water pump housing, Sixpack rods, forged crank, flat top stock pistons, "452" heads. Both sport stock valve trains. The crank on the 73 is needing remachined due to cam wipe out. The crank in the 74 is pristine.
Also have an M1 single plane, 750 CFM elec choke double pumper, Comp Cam CL 21-306-4 and lifters, a Mallery Unilite dizzy w/ vac advance, block hugger headers, 3" exhaust, a set of fully machined and prepped /assembled "516" heads
My desired goal with all this mess is 400+ hp and TQ.
What I need is a recipe to reach this goal using the parts I have if possible, and recommendations of what to swap out if not.
I'm about to send one of the blocks up to Vermont Engine for machining. What should I tell him to do to that block, and which block should I send?
Thanks for you guys help and wisdom. Ghost.
