DWinTX
I have to pull the 727 out my 65 Coronet. Fortunately I have a lift and high trans jack, but I've never pulled a trans with a lift before. How do you support the rear of the engine? On the ground I could put a jack, blocks or whatever is around and will hold the weight. But what do I use when it's 6 ft in the air?
Doing some searching on the web I found someone say they just let the pan sit on the drag link. Seems like that would be a lot of weight on it. What do you think?
