sunger
I am thinking about buying a 68 charger R/T hemi car, and found this one. As I have dug into it some, the seller sent me the following:
While building this car, had to find many parts. Received the car with many missing parts when purchased. The restoration took 3 years to build. Govier noted the car obtains its Original Fender Tag. Govier noted that the body numbers match. It has the correct Hemi 048 Radiator, Hemi 80 and 81 Torsion bars, Hemi fan 2863215 and the original leaf springs. It also has the correct 742 case for the 8 3/4 rear end. Govier noted the vin seems to have been replaced at some time. At some point in this cars life the original vin plate was lost. The replaced vin has been installed with the original style rivits. He verified that it is a true XS29J8B car which is what corresponds on the vin. The only part of the vin that he thought was not accurate were the last 4 digits, but he said it still was a true "J" code Hemi car and documented it in his authenticity paperwork. In 1968 the last numbers of the vin have nothing to do with the body numbers. The body numbers which are on the car, are located on the fender tag in 1968. He noted the fender tag is original and codes as a 426 hemi car, plus he took photos and noted the original hemi torque boxes, etc. on the car. Govier verified/ authenticated this as a Born 1968 426 Hemi Charger R/T, a True "J" code car.
I am balking because of the questionable VIN as noted. I know the VIN is generally located on the left side of the trunk under the trunk lid molding, and question why it was not checked. Is this something I should pursue, or put the peddle down and get out of Dodge. Thanks
