- 8:54 AM
- Apr 13, 2012
- Granite Bay CA
My pump has no shims in it. I only got to drive the car with the Borgeson for a short time before the camshaft went bad but it steered fine. Effort was a LOT less than with the Firm Feel and Fast Ratio steering arms.
Regarding the Saginaw pump pressure.....
The reservoir and pump I pulled from the junkyard was from a heavy 1 ton 4wd truck with hydroboost and a slightly larger 6 1/2" pulley.
I could be wrong but I'm thinking that if this was adequate for a truck, a car that weighs 1500 to 2000 lbs less should be okay.
That pump surely turned slower than mine does with a smaller pulley. If I needed to, I could use the other pump with the smaller 5 1/8" pulley......I could just swap the reservoir again.
