"Just Like" I love that statement, do you also believe in the Tooth Fairy and Leprechauns?
Here’s couple of examples of “Just Like”
SB Mopar distributors imported…. “Just Like” the Factory, except they didn’t get a good weld on the plate to lower shaft and they had to come here…..all of them, to be disassembled and re-Tig Welded which cured the 15* timing bounce.
BB Mopar distributors….. “Just like” factory, except they put ½ the reluctors on upside down and the phasing is 20* off, trucked to us to correct all the inventory and return.
I won’t bore you with the Ford and GM Import distributors that we’ve had to fix, I think the Import GM stuff is the worst including MSD’s Budget HEI distributors. They eat the gear off the bottom (like all the Chinese distributors) in few thousand miles, the thrust collapses because of the inferior metal they make it from, the pivot points for the weights are in the wrong location and they won’t return to the idle stops but hey .....looks “Just Like” factory and the oil filter should catch most of the material.
I guess your spinning the motor 7500-10,000 RPM as you feel you need a bearing to protect against the side load caused from your point’s spring. If you use an electronic distributor there is NO Side loading as there’s nothing loading the shaft that’s why the bushing with NO LOAD lasts 250,000 miles. How long will that bearing last? We change a lot more bearings than bushings.
If you’re concerned about stabilizing your Mopar distributor then make sure your intermediate shaft to oil pump is good and the tang fits in it snug end to end and side to side, always replace the bronze bushing in the block where the shaft rides, that’s what will stabilize your distributor.
“ease of tuning” there’s one of those Leprechauns, our distributor machines (4) all run on a ¼ HP motors, we let them run at 8000 RPM for hours sometimes days and they never hot. That would free up lots of HP I’m sure.
“I do have a MSD 6a box” so all you need is a trigger? So why are you looking at a distributor with a module in it? Like I said, call NAPA and ask them if they carry a module for any of the imported type “R2R” (there’s that tooth fairy) distributors. Look inside any of them, do you have the tools needed to release the electrical connectors? Unless your MSD Box has been sitting in the rain it probably works fine, in fact the older the better the new stuff sure isn’t my choice the CD1’s run circles around them. Same for the coils, they were designed and manufactured by Andover here in the USA, now they’re made in …..guess. Can you guess where MSD has their caps and rotors made? You know, the $40.00 red ones.
“Mopar distributor but its vacuum advance and my cam is pretty decent” How big is decent? Do this test, at Idle crank the timing to 30* advance, bring the idle back down and adjust the carb to give you best vacuum, now tell me what the vac at idle is? The rule of thumb is “If the motor will make 10” or more of Manifold Vacuum at Idle with 30* timing then the engine will greatly benefit from a properly set up vacuum canister” Conversion of a vac distributor to all mechanical is a $5 charge when we curve it.
Steve: “I have a MSD R2R distributor and it came with advance stops and springs for adjustments.”
I have a good set of 45* long needle nose pliers and a syringe I use for CC’ing heads, but I still can’t inject Novocain pull my own tooth. Having the tools and parts still doesn’t help you unless you know what you’re trying to accomplish…that’s takes years to learn.
You can reach me in “Live Chat” from my website I’m here from 6a to 4p Pacific Just Google ... Mopar Ignition Tuning.
Sorry for my sarcasm but I get tired of all this internet hype and misleading advertising by importers with no data to back any of it up, we have the data we’ve run and torn down almost every distributor you could possible buy… some stuff is decent but a lot of it is just creative marketing.
Don’t call a proctologist if you need glasses, you may end up with a Shi**y outlook on life.
