mdcops8
Okay so My car was running great until i had to screw it up by replacing the distributor. I had an OEM distributor and accel coil and went to put in the new accel distributor and i get nothing. I have the distributor wire hooked up to neg terminal on the coil. Positive coil terminal is connected to a ground on the mounting bracket, the ballast resistor, and there was a piece on it with a thin flat piece of metal that matched up to another thin flat piece of metal on the top of the coil mount. That piece broke off but it was never connected anyway. What was it? And can anyone tell me if this is the right wiring for the distributor and coil? And if correct, and help on what i should check? Thank you in advance. Oh yea, the engine cranks fine but wont start.
