Rear bracket that the fold up license plate holder mounts too
This is what I mean
View attachment 1767168View attachment 1767169
Did you tried with light assembly in place?
73/74s (or at least those 73/74 I have worked on) doesn’t have that extra surface on license bracket, so I can install without deal with the light.
The only difference is try to fit with or without light in place. That’s all.
I am not seeing how adding the light assembly first is going to allow the one I have fit
Backwards… first license plate bracket… then after that, the light… will overlap that extra surface on license bracket
I tried to put I on with the light bracket it off and the license plate bracket hangs past the bottom of the bumper
Tab provisions or bracket could be bent?
All what I can say is how is made the assembly. Now, dealing with used abused parts (or new bad repros) on a tight areas can be tricky. Hard to say from the distance
Is this what you need ?
