matthon
Pulled one axle out, everything was put together correctly, see pics.
Face of axle to groove on backing plate 3 15/16.
Inner drum face to outer edge of drum 3 1/2
Face of axle to rim on backing plate 3 3/16
Inner drum face to groove on outer edge of drum 3 1/8
Whether you get my measurements or not, there is plenty of room for the drum.
Drum from 64 Fury, which has 65 brakes, is identical, exactly, every measurement on this drum and the new is the same.
Fury drum on Dart, same issue, Dart drum on Fury, works fine, just drum on or drum with steel wheel.
The shoes from the Dart in a few spots, which are hard to find, are not quite 1/16 wider than the Fury, virtually undetectable.
Put Dart shoes in Fury drum, no difference whatsoever.
Fury and Dart brakes are identical, they look identical - except 1 thing.
