Anybody know if I have to take the dash apart to reach the passenger compartment side of the bulkhead connector? I looked under the dash but I couldnt see it
You can get to it but it's less then a pleasant experience.
One thing you should know is Chrysler doesn't use the same Packard terminals as the commonly available GM type. They have their own style. I can't remember which, but one is a 55 and the other is a 56 or something like that. I have been able to make the GM ones work but a little filing will be required. Just compare the two styles and it will be obvious what you need to do. Get good at soldering!
