RRSweden
Hi.
I could'nt get my engine to start. I'm thinking it's got to do with the dist. advance timing..
Some of you has helped me along the building of my 383, but for those of you who don't know here's some info.
383 with .030 overbore
compression ratio:10,5:1
closed chamber iron heads.
comp cams xe268 shaft.
stock distributor.
I had it set to 11* avdance, plugged the vacuum advance, and filled the floaters (holley 650dp) up manually. -Nothing.
Tried with some start-spray, but it didn't happen much. A couple of coughs at the most...
Then I backed it to like 8-10*. Backfired after a while.
turned it up to like 12-14 and it backfired again.
I don't know for how long it use to take a rebulit engine to start.
I have the stock starter and it feels like it's really slow.
I'm also kinda scared of the backfires and fire in the carburetor, as I'm pretty new at this.
Where would you start? Is'nt 11* a good place to start?
stock distributor.
