- 8:09 AM
- Jan 16, 2011
- NorCal Sierras
Impressive work on that exhaust system....
TACH=CONFIG]125553[/ATTACH]
As I've said before, the final tips aren't on yet to bring them out flush.That wasn't a wish, it was mental preparation because I'll probably need it. ThanksCarefull what you wish for. I hope everything comes out fine with tranny and you can start cruising and put all the troubles behind you.
Headed over in a few, going to pull the valve body and do an air test on the tranny, I'll know whether it's in the tranny after that. I don't think 90 psi would blow anything, it's what B&M called for besides those tranny seals are a pretty tight fit but we'll see. I actually enjoy working on them, don't know why.I'm going to go with internal leak. line pressure spec is 54 to 60psi and you're at 90psi. So you probably blew a seal on a drum. I'd still check out the valve body first. It's easier than pulling the trans back apart. I hate transmissions, as far as I'm concerned they work by magic. Good luck with it.
