Hey all,
I got a 318 with 340 heads, a Holley 1850 600cfm and hemi street performance cam and I’ve never been able to lean it out. The car runs super rich with the idle mixture screws out a turn and a half. The driver side screw is a bit wobbly and doesn’t respond like the passenger side screw which is suspicious. I drilled 1/8 holes in the throttle plates thinking that would help but I think it made it worse, it’s like it’s not getting enough fuel without the idle mixture screws turn out so far otherwise my vacuum drops from 15 to 5 going into gear and i stall. I got the secondaries open up about two turns, I can’t get it to idle without them open so far.
Is this a sign of a bad electric fuel pump or just poorly tuned carb/wrong carb for the car???
