vanrj1
Setting idle mixture screws on edelbrock Help
Ok, so I posted in another post that I have low vacuum and later ran across a thread talking about timing. there was a link to Diamondback engines page and I found this white page about tuning dual carbs. After following the instructions for this, I got my vacuum steady at 18hg by adjusting idle mixture screws and running smooth. That being said my idle is now 1100 with idle screws backed off all the way. Timing set a 8° BTDC runs real well but idle seems high. here is link. it says to adjust to get highest steady vacuum. look at number 3. , 1. vac gauge method
This is a poly 318 with 264/450 cam
http://www.diamondbackengines.com/technical-white-papers/setting-up-dual-quads/
