Side window alignment
jimbosride
4:59 PM
Washington state
When restoring the 65 dodge I missed some of the details. What is the best way to adjust the window angle? Can it be done thru the door plugs?
or does the panel have to come off ..... the driver's side is perfect.
yep have a FSM ... just thought I would ask
Thank you ..... :thumbsup:
The good news is the belt line/lower window alignment is close.. On a 66-70 the top in & out is on the bottom of the door... Don't know about your 65 but I'm guessing it's the same... If the up stop adjustments is off then yeah, the door panel needs to come off...
Take a photo of the bottom of the door & the front upper jamb area & post them...
after looking at it .... I'm pretty sure the panel will need to come off. I see the wing window frame Allen bolts ... but the angle bolts are on the inside
time to study the FSM :rolleyes:
