Altered64
Im just trying to pick everyones brain while i continue to look for the gremlins that are hiding in my motor.
The motor is a bone stock 64 slant 6
52mm t3/t4 turbo
Intercooler
Methanol injection
Megasquirt EFI
Stock points ignition with a hot coil
The problem:
The car runs and drives fine except when the boost goes over 6psi, it builds boost real fast up to about 10psi but then falls to about 5.
If i keep on the gas it continues to do this up&down stuff 8-5psi
Cant hear any detonation, but there is def a loss of power.:sad10:
This has been happening since the the turbo went on about 8k ago.
Heres what I did so far:
Its getting plenty of fuel!
I played with the timing, the mechanical advance, plug gap and heat range.
Adjusted the tension of the wastegate and blowoff valve.
Nothing changed the problem!
I see others with similar setups pushing over 20psi, why cant I do that.
Any help would be greatly appreciated.
52mm t3/t4 turbo
Intercooler
Methanol injection
Megasquirt EFI
The problem:
