Wietse
My cam is 238/244 @ .050" (283/291 advertised) so just a little larger but .572/.576" lift and more area under the curve.
I had set my cranking timing at 16* and idle at 20*, it starts easy but it does not stay running by itself as well.
I need to give just a little throttle (3-4%) to maintain a 1000-1200 rpm idle for a few minutes otherwise it will stall.
If i slowely release the throttle the IAC will open up to 100% but cannot maintain the idle speed of 875 rpm and will slow down untill stall.
Once warmed up it idles fine, i only have 75-80 kpa manifold pressure which is problematic to say the least.
I think yours will need some learning time and to get the fuel learning table filled in, it will add/reduce fueling as a matter of learning.
Like i mentioned before, you can change the idle AFR to a little richer and see how that works, with your vacuum surely it will run better than mine.
And btw, that is a nice '68 Charger.
My Coronet R/T had originally that same color, but some PO had painted it Sublime green.
