Mike Gaines
- 12:36 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
This really has been an interesting thread. The distinction between hydraulic roller & solid roller durability is still not totally clear to me. Hydraulic roller with the proper cam profile for "street" application sure seems to make sense. For drag racing, solids are straight forward, durable & proven for the intended use. Solid rollers for drag use clearly allow for much more radical lift rates. Newer solid lifter cam profiles, I'm told by my qualified builder, are much more capable of the performance levels, but maintain the inherent durability of the solid. My roller experience is 30 years old & I didn't have roller problems, but spring problems. It's clear that springs have come a LONG way since the 80's. I'm going with a solid lifter cam on my new motor, and planning on not letting valve lash get out of control. My only "broken" motor came from a backed off adjuster, lost pushrod & lifter, no oil pressure during the run, seized bearings. I will be installing a LARGE low pressure warning lite with my new motor after recalling this failure.
Mike are those lift numbers with the 1.6 rockers?
NO...Those lift numbers do NOT take into consideration the 1.6 rockers which would make the lift MORE.
