@IQ52
how long did it last ?
or was it just for dyno purposes in testing, curiosity ?
what did it do ?
was it a big or really any difference ?
did you do something different with the lash ?
I was always under the impression the
solid flat tappet ramp speeds angles
were much steeper/sharper at the peak
& dropped off way faster too
(to help close the valve faster & not bleed off cylinder pressers)
seems a Hydraulic camshaft as the base, with solid flat tappets
wouldn't be Ideal for optimum power
seems like a Solid Flat tappet cam would be the opposite
of the hydr. flat tappet lifters, a really really sharp opening & drop off,
working, cycling or slamming the lifter plunger much more
be prone to wear/breakage (???) because of the ramps/speeds/angles etc.
I was always thought &/or I was told the solid flat tappet cams
have a different/higher or deeper level of heat treating
than the "typical" Hydraulic flat tappet camshafts had...
may be different today
Inquiring minds want to know...
I can take it
maybe you could shed some light on the subject
