- 2:58 PM
- Dec 21, 2021
- Miserable Smells TX
Hello everyone!
I’ve been looking around for a replacement for my Mallory Unilite that crapped out on me. When doing research on a replacement, I came across HEI ignition, I know it’s GM, but it’s not a bad system, and parts are easy to get, and they seem to be better quality then our mopar ignition boxes. Also it can be done pretty cheap, I know some of us are on tight budgets.
The problem is you either get an ugly HEI distributor, or people make a mounting plate under the distributor to put a 4 pin HEI module on. There’s another option that’s almost invisible.
4 pin HEI modules can be found anywhere. Local auto parts stores, Jegs, summit racing, rockauto, anywhere parts are sold. And you can get anything from a stock replacement, up to a high performance unit with a rev limiter. Chrysler ignition boxes can be found at junkyards, swap meets, eBay, or in your parts stash. You can use a points distributor or an electronic one, and those are pretty easy to find too.
1st You take an Old Chrysler, or old parts store ignition box, and gut it
