Mason, the wheels need to sit on the floor or a drive on ramp / hoist while someone turns the wheel to locate loose parts.
Just a rocking back and forth will show whats loose. You do not have to make full turns ect.
The weight of the car acts to hold the tires/wheels in place so the loose joints will show.
Have the car shut off while doing this.
Negative camber on your tire /wheel is what is going on with the torsion bars lowered down like you have them. The more tire width you have the more the situation compounds. Sitting down on the rubber stops not only affects the way the car drives it will trash your tires in sort time. Yes you can have the low / real low look if you like but you can only go so far with the Torsion bars. To get were you like you may need drop spindles. Then you start running out of ground clearance. LOL each action has a reaction.
All the different parts work together , bushings , box, joints , tires , shocks , toe in, camber , castor.
https://www.bridgestonetire.com/tread-and-trend/drivers-ed/tire-alignment
Look this link over it will explain alot.
