TetanusShot
Has anyone on here damaged a motor from running a standard pan at high rpm too long?
Good question.... I have not.Has anyone on here damaged a motor from running a standard pan at high rpm too long?
Great! But, what was the situation exactly? What happened? What parts? What clearances?Yes
Oil system is not a place to skimp on a performance build.
Can't you shim the engine up?Everything I am reading says the hemi came with a 402 pan which was a 5qt. system...….
The Hemi pan came on so equipped B-E cars. It should fit your 68, had a 70 383 Charger swapped the 402 for the Hemi pan and My 68 R/R has it. No fittment issues. What 6qt pan are you running?Everything I am reading says the hemi came with a 402 pan which was a 5qt. system. What is the pan that holds 6 qts? My 6 qt pan rubs the drag link on my 68 Charger so I want to find one that fits and not do this again on my current stroker build. Any info is awesome!
Would almost bet your not running 6700 rpm for extended periods of time with that stock pan. Fifteen to twenty second runs would be the limit and marginal at that.I have a stock pan. Shift at 6700 rpm
which oil pick-up do you have?I run the 971 pan with 6 qts and a hv oilpump with no problems.
