Stroker Motor .
440 or 400 Block what say you.
  • Total voters
    31
Stroked 400 block to 512! 9.8 cr
Very good on street!
From what I've learned go ARP throughout no matter which way you go
Good luck!
572 Mopar megablock,15-1, 285/292 on 112 lca .800", ported -1 Indy, Jessel belt, T&D 1.7 paired rockers, 7/16 Trend pushrods, Isky red zones bushed lifters, GZ vacuum pump. And now the real speed secret. Indy box ram with 2 nearly box stock Eddy 750's. On a side note: Canyon 707 did your new motor come from Al A?
Doug
Yes it did I bought it from him in jan
400 Block ('72)
440 Source 512 Stroker kit
10.6:1 (93 Octane Pump gas)
CNC Ported Indy EZ's
Lunati 60333 Solid roller
Indy Tunnel Ram
FiTech Fuel Injection
TTI Headers
734HP
675 Torque
Ya don't see a lot of big hp builds with FI. Decent street manners?
Doug
yes it did Al; raced here in Sonoma many years.
I'll need to take a closer look at my 400 blocks & the 440's I still have to check out the main web difference. One thing I noticed in the 440 Source info that is not correct, the reinforcing rib below the freeze plugs started in '68. I've had at least three '68 blocks with the rib. '66 & '67 440 blocks no rib. The thin / thick cylinder wall issue sure is still interesting. The '76 &'77 blocks I sonic checked were slightly thinner than the '68 '69 & 70 blocks I had but not very much, maybe .015 - .025.
Hes a good guy, That'll be a good piece.
Doug
He is a good guy. we talked about doing some work on my 440 but after it lost a rod lt was time to look at another motor. He had a 440 and a this 511 so it was to good a deal to pass on. The motor is in and the trans goes in this morning.
Like Doug I build my own engines and trans and rears and so on. I took auto shop in high school and have tried to learn all I can over the years. I became a tech not only because I love it but I wanted to build all my own stuff for my cars. The 493 in my 63 I built myself and its a fairly mild combo by todays standards. I just wanted a 10 second driver that I could drive to the track and race in full street trim. And honestly I have not really ever got after it because of my health as I have alot of joint problems and it really is hard for me to stand around at the track to long and working on the car really bothers me so I just do a little at a time. But I would not want to use a stock 440 block and push much more then 650 hp. Much over that I would seriously consider an aftermarket block. I never dynoed my 440/493 but by the 10.70 ets through the full exh on 92 pump and 3725 lbs I believe it makes about 575 to 600 hp at the flywheel. If you click my sig and schroll down to the 2011 update it tells most of my 493 build. Good luck with yours. Ron
No, Chrysler CTC in the electrical lab. I LSM is close to my house though. Just like to build my own stuff. It's as much fun to me as racing. Engines, trans, axle,cage, sheet metal,wiring.
Doug
Ok noticed you're in the same town, LSM is doing my custom grind cam so I figured I'd ask
