The initial will have an effect on takeoff. If you only have 10 now, it may benefit bumping that up. Of course you will need to limit the total when you do that. I find that 18-20 initial works well on my cars.
That cam will need a LOT more timing at idle than it currently has & it is the reason you are getting poor running. In the Edel owners handbook, there is half a page about dialling in low vacuum cams [ which is what you have....]. Read AGAIN the link I posted in post #12.
One of the fixes is more timing at idle.
Try this simple 5 min test: engine idling, turn dist slowly CW; this advances the timing. Idle rpm will increase [ how did I know THAT ]. Keep going until you have the highest rpm/smoothest idle. Then check the timing. Do not be surprised if it is 30+ degrees.
