An inductive system works by turning the coil's primary current on and off, thereby INDUCING the high spark voltage in the coil's secondary windings (the process is called inductive reactance). An MSD system uses a CAPACITOR DISCHARGE principle, where the capacitor in the MSD box, furnishes a high voltage pulse to the coil's primary winding, which in turn, raises this high voltage pulse, thru the same inductive reactance principle as previously described. The capacitor discharge system DOES NOT CREATE THE HIGH VOLTAGE SPARK VOLTAGE DIRECTLY BUT THRU THE EXISTING COIL WINDINGS.....BUT IT PROVIDES MORE ENERGY TO THE COIL'S PRIMARY (in terms of watt/seconds or Coulombs per Coulomb's Laws) FASTER, ALLOWING THE COIL TO PRODUCE MORE ENERGY IN THE SPARK VOLTAGE. The system still uses the distributor to control the on/off - when the spark occurs function. Instead of the coil's primary winding voltage of 12 volts, with a conventional ignition system, a CAPACITOR DISCHARGE IGNITION SYSTEM provides the coil's primary winding voltage approximately 400 + DC volts to yield more spark ENERGY. The term CD IGNITION SYSTEM is a misnomer but a combination of s conventional coil ignition system with a CAPACITOR furnishing the coil's energy source. Thus endith the lesson......class dismissed.......
BOB RENTON
