prostockstan
as the vacuum catches up the rod will go down so your ok. When its out on the road is the only test. If its uder load with throttle wide open the needles will be up don't worry about that, then as you let off the gas and rpmm strarts coming down the rods will slowly go down. its all progressive with throttle and load. in the shop there is no load. wack the throttle they should go up let off they go down. Use the heaviest spring possible that allows the rod to stay down at idle without dancing.
