miller
Have to wonder just how much difference, flow and distribution, there is between the two?The crossram we are running is an A&A 440 not the max wedge one.
You would have to have an O2 sensor on each primary header pipe to figure that out. I guess we will never really know. I think the old timers did most of the homework for us. What we do with all this information is up to us now. Spread the joy! and the Mopar love.Have to wonder just how much difference, flow and distribution, there is between the two?
I hope I didn't offend you. You are correct that the manuals and literature will help everyone understand the theory of this type of carb and is a great place to start for the inexperienced.FYI, I was referring the member to the manual to get an idea of the relationship between the jets and metering rods and how changing either one affects the mixture, which also applies to the Carter Super Comp carburetors of old.
I keep seeing references to staggered jetting. The specs given were for WOT for the Chrysler super stock cars. Is that what your ride is going to be used for? If so, the sizes and manifold modifications in the Direct Connection manual will be applicable; however, if the car is street driven, those numbers will have very little relevance. A wide band dual reading A/F ratio gauge with a sensor for each bank if running a crossram will help get the jetting spot on.
That's what we did to save time as long as the new rods are giving or taking away fuel in the right RPM range where you might be having issues. If it stumbles right off the bat you can move the accerator pump rod towards the plunger. This will give more fuel on initial throttle. If you move the rod down a hole, away from the pump it gives less initial fuel when accelerating from a dead stop. The rods, jets, and accelerator pump all affect the total outcome.in my shop..they start down..I crack open the throttle,,they go up..without any movement of the throttle blades..they go back down on there own..is this correct?.thanks..to lean it out some,,75-65 rods?without changing jets....
Unless im missing something, I don't agree with your rod theroy. At low vacuum (wot) the rod is up with the small diameter blocking the jet. At lighter throttle (depending on engine vacuum and spring selection) will determine what portion of the rod blocks the jet. Rpm does not control rod movement. Rod movement does not control fuel curve based on rpm.I like to get to the point where it pops lean and go up larger with the primary jet or smaller with the rod. The larger diameter of the rod is the low rpm diameter of .071 the small diameter of the rod is the high rpm end of the rod. The high and low numbers of the rods switch around so see what rpm is the issue and tune the rod according. Smaller diameter rods flow more fuel around the rod. The larger the rod end the leaner . Remember the rod goes down into the primary jet and fuel is flowing around the rod ends.
Doug
Vacuum is the only thing that controls the rods. I only meant that we we had a stumble at 4000-4500 we went with a different rod which gave us more fuel at that rpm range.Unless im missing something, I don't agree with your rod theroy. At low vacuum (wot) the rod is up with the small diameter blocking the jet. At lighter throttle (depending on engine vacuum and spring selection) will determine what portion of the rod blocks the jet. Rpm does not control rod movement. Rod movement does not control fuel curve based on rpm.
Doug
2200 ft is barely enough to worry about, maybe one step up which is about 4%. The distribution in these manifolds is nothing to write home about anyway. (look at the jet spread to start, wow). Make the seat of the pants feel good and enjoy. The max wedge I alluded to previously is based in Phoenix. Stock factory jetted 3705's. Drives excellent and gets 14.5 mph highway.I am really interested in all that I have read here.One question came up.I was just thinking of the Altitude of where you are, and the difference that might be as far as tuning in reference to density altitude in your location ? The altitude of Lancaster Pa is around 360ft.Where I'm at in Nevada it's 2500ft. So would the size of the jets and metering rods be different in each location according to atmospheric pressure ?
total,,@ .050 its 280-290..Is that the duration at .050 or advertised duration?
Check for a vacuum leak, it should idle. When warm my racecar motor will idle at 1000, 2 Eddy 750's. Cam is 285/[email protected]/.800"have to keep the idle high though..cam does not like idling and to put in gear below 1500 rpm's.will slow and die/foul the motor...duration is 320-330....
Are you running this cam on the street? In a 512? WAY too much duration, even in a race application.total,,@ .050 its 280-290..
probably right but,,that's way it came,,straight out of a barn ..440..when the .010 over 426 marine motor goes in..it will have a crane r280 roller ..Are you running this cam on the street? In a 512? WAY too much duration, even in a race application.
Doug
