Here's the simplified version;
You nailed it.Lightbulb moment.
I was just here talking to somebody wondering if I had the function of the brown wire wrong. I assumed the brown wire had power coming from the resistor and going somewhere. Then we talked it through.
So:
The brown wire feeds the blue wire that it's connected to during cranking. During run time, that wire does nothing and the blue wire gets power from the other side of the resistor. In this case, my black wire.
Did I get it right??
You, sir, are a scholar and a gentleman LoL
Lightbulb moment.
So:
PM SentLightbulb moment.
So:
Yes, it did!Tie the three wires together problem solved.
Where did you mount it and what did you use?I found when turning from run to start there is a break in between the 12 Volt circuit all the switches do it ,i had to put a 10 second timer that is triggered by the start circuit & stays on until the key returns to the run position. What happens when going from run position to the start position & back there is a momentary break in the 12 Volt supply to the EFI 12 Volt switched supply , sometimes but not every time this causes the EFI to reset resulting in a high idle (Could be the DBW) resetting .
Using a Terminator X Max also does it on the Fast Sportsman EFI
This sounds like a simple solution.Positive hub under the dash, both IGN and RUN connected here, along with EFI and Coil/Distributor.
That will bypass the ballast. No matter where you link both circuits, any link will bypass the ballast (for anybody who cares, of course)This sounds like a simple solution.
Still having problem's with this will update once i come up with a fix.Where did you mount it and what did you use?
Like you said the problem with our ignition switches there is that moment in time where neither the crank or run output terminal of the switch has voltage on it, due to the way the internal contacts overlap (or fail to). No problem for oem and even some EFI as it happens so fast, but some EFI systems seem to be more sensitive to it than others? What I've done is mount a starter button up under the dash right there that intercepts the yellow ignition relay wire. The key gets switched to 'run' and stays there, button cranks the engine without disturbing the switched feed. No more voltage interruption and the button is out of sight.I found when turning from run to start there is a break in between the 12 Volt circuit all the switches do it ,i had to put a 10 second timer that is triggered by the start circuit & stays on until the key returns to the run position. What happens when going from run position to the start position & back there is a momentary break in the 12 Volt supply to the EFI 12 Volt switched supply , sometimes but not every time this causes the EFI to reset resulting in a high idle (Could be the DBW) resetting .
The button add doesn't bypass anything except the 'crank' position of the factory ignition switch. NSS still works as designed...you're still sending 12v start signal to the proper terminal on the start relay, which is where the NSS enables/disables engine cranking.As long as it does not bypass the nuetral safety switch allowing to start the car in gear
I am working on make a PCB with a micro processor works in such a way as soon as it detects the start command it turns on a relay to bridge the start /run circuit for 2 seconds then turns off .
That way it still involves the safety nuetral switch ,wheather it is fast enough to detect the initial crank pulse remains to be seen .
I have tried to silver solder the contacts on the ignition switch to eliminate he open circuit between start & run but it is messy also found the delay between the Chinese switches have a larger blank spot between the start & run circuits
