Thanks much for the offer... no need, I've found the same wording in the `63 manual.
Let me explain my current confusion... I thought I was paying close attention at teardown lol. I assumed there was good chance this had never been apart.
So, first mistake.... second mistake, never gave it a thought to check the end play.
So, looking it over while apart....I got NO shim on the driver side, just a foam gasket (no mention of those in the manual). I can see inner seals are not OEM, but all clean and still Timkens for bearings.
Passenger side, three shims and a rusty mess in there.... and a foam gasket. No mention in the manual, but I suspect maybe the shims should have been coated in Copperseal or soft Permatex??? Otherwise, I would think any winter or even rainy driving is going to get some moisture in there??
So, back to the end play...I'm cleaning up the backing plates now, and I'll mock it back up and see if it's good...should be no reason at all to believe that it could be any different that it was when together recently and sounding good, since the thrust blocks are identical size-wise...
I'll repost soon. Thx much.
