The Original Hemi Charger Is On a Hot Streak
Speedbird
Bird of Pray
6:10 PM
Status Quo
https://www.hagerty.com/media/market-trends/hagerty-insider/the-original-hemi-charger-is-on-a-hot-streak/#:~:text=Since 2019, values for a,built between 1968 and 1970.
For several reasons, today’s recently departed Hellcats owe their thanks to the 1966 Dodge Charger, like the one profiled and driven here. Though mechanically the original Charger owed much to an existing Dodge model (the Coronet) this was the first time that the Charger name denoted a distinct model, rather than a trim package on another line. The ’66 Charger was also Dodge’s opening salvo in the muscle car wars, mostly because parent company Chrysler forbade it from building a smaller (A-body) car to compete with the Mustang. And, of course, there was the engine.
The Charger debuted in 1966, available with Dodge’s 426-cubic-inch, 425-hp Gen II Hemi V-8. Chrysler engines with hemispherical (well, domed) cylinder heads had been around since 1951, and drag racers had been competing with the Gen I Hemi for years, but as of 1962 Dodge had new ambitions. It was tired of watching GM triumph in NASCAR, a series in which, as of 1962, none of the Big Three were competing, at least not officially. As of the 1964 Daytona 500, Chrysler decided, it would no longer be a bystander in NASCAR, or for that matter, in drag racing. To participate in the stock car series, it needed to build a production car with a version of its racing engine. Thus was born the “Street Hemi.”
Some questionable info in the article. A disconnect plug so engines could be swapped out faster. I assume they are speaking of the one on the valve covers which is usually described as there to make pulling the valve cover easier for adjusting valves. And a 3-speed transmission was standard with the Hemi? I’m waiting for one of those to be documented. And the instruments electroilluminesent lighting runs off of 240 volts? Guess the 66/67 owners here will have to address that one.
As you suspect - 3spd manual was only available for, and standard on, the 318...not any big block. They must have neglected the word "automatic"; 3spd TF auto/3.23 open axle was standard for the '66 Charger w/ 426 Hemi. Add a Sure-Grip to that was optional. Only other option was a 4spd manual w/ 3.54 SG rear end.
Cropped image from dealer data book lifted from Hamtramk Historical.
Yes, the electroluminescent lighting is driven off much higher voltage. There is a separate transformer behind the glove box.
Now, where is that article about the “Bloomington Ghost”, reported to be the first Hemi Charger built. Owned by a little old lady named Cora Case, it was driven the first year she got it, and then she received a company van and put the car away….for like 40 years. Brought back to the road by her TV repair man, Galen called it the most original surviving Hemi car in existence. Great story, beautiful car, in the ugly Mauve color from 66. It’s a great story!
Interestingly, the 1966 Chargers equipped with the base 318 and 3-speed manual transmission, had column shift (3-in-the-tree). The standard full length console carried a blank top plate with no shifter in it. In 1967, the console was an option, so the blank top plate was a one year only deal. Canadian built 1967 Chargers still had 318 Poly in them.
Her name should have been Chase.
Mauve is the universally recognized color for danger.
I was there in 93 @ aurora Missouri when it debuted. Parked beside him. An early build car, not sure about the 1st.
1st mauve hemi car
I was there in 91 @ aurora Missouri when it debuted. Parked beside him. An early build car, not sure about the 1st.
1st mauve hemi car
When they took down the gas tank, on the pad there was a handwritten scribe that said “first one”, and “hot rod”, and I think it was Galen that gave it the 1st Hemi Charger built moniker. Not saying that his word is gospel, but it’s certainly an early car, and quite possibly the first.
As I recall he said, "#1 hotrod". Now that could have been , on that shift, or for that guy, or who knows. I remember a dent in the hood from a mechanic closing it with his pocket knife
I think the dent was from the TV repairman leaving a screwdriver on the air cleaner and closing the hood
The Chargers weren't built in Canada so they had the LA in 67.
I do have a 67 Belvedere ll with a poly though..
I thought they were built in Windsor, too. I guess my friend's Charger must be a '66. Sorry. The 1967 Coronet wagon I bought had a 318 Poly in it.
Yes. All the Canadian built vehicles that had 313’s were poly’s. Same block as the US built 318.
That chart is very interesting. My Charger was a 361 factory air car. I always thought 2.94's were standard and 3.23's were optional. Apparently it was the other way around, and air cars got 2.94's.
