- 5:42 PM
- Oct 25, 2010
- Monroe, New York
Mmmmmmmmmeat. worked out very well…..
What's your POINT..
Salt doesn't pull water out. It enables water to come through the cells, but it also allows flavoring to go into the cells, which is why I always use salt. What actually stops the juices from coming out is searing the cells closed.I read an article that says to salt after the steak is cooked. The reason, salt pulls moisture from the meat and steams it. I've tried this the last time I cooked steaks and turned out perfect!
