The Willomet Charger
Art in motion!! Are you doing boost on your Lq4 6.0 or just keeping it N/A? one of the best blocks to start with.
Hey, thanks. I do like to think of this as somewhat of an art project, stretching my skills.
Boost is the plan. Likely a Procharger D1SC or F1. Still a ways off from finalizing that decision.
What are trying to convert on your 6060? It looks like its out of a GTO or CTSV.
The 6060 is out of a 2011 Camaro. I’m just going to convert it to a slip yoke Magnum with the 3.01 first gear - relatively minor changes.
The 3.01 related input shaft on the TR6060 still has 3/16” interference with the crank. This includes the Magnum front cover, 1/8” scatter shield, and QuickTime bellhousing. I probably just need the American Powertrain 1/4” bellhousing spacer, so I’ll run that to ground at some point tomorrow. It’s in stock locally at Summit.
Meanwhile, got some chassis junk done.
15* intersecting at the bend in the inner pieces - kind of like avoiding a dead node.
The inner rails are canted at 15*, so they make a nice right angle to the forward outriggers. Neat detail I stumbled into.
It was nice weather, so I could work with the doors open for a change.
David
Just noticed your garage walls, I like it.. gives it a nice touch. I am really liking the way that frame is coming together, looks very stout and professional.:thumbsup:
Thanks! We live in an old neighborhood, and I had a lot of reclaimed lumber to make use of.
The frame design is strongly inspired by what I saw at the Roadster shop a few years ago.
David
Cherry picker modifications so it’s easier to stab/pull the engine while the car is on the frame table.
David
Another good few weeks of work, and a decent series of milestones.
Lateral chassis bits are burned in.
FWfBdYhMYVTiIlovwt5vsIvtDaEwYz7EYpOchMfihkVd6d_Aie3IhSkOzXExIjDR8dUmIkeXtZX3ZiFP-U=w1024-h768-no.jpg
GrjdXsUN7mfhQ4Dh6iIYVMbuxyTGkX99Fsy8wMff2cgoFfH9m6q22x5IQw4aE71rvY-aNzjat6ddQcwaOQ=w1024-h768-no.jpg
Just about ready to stab the engine and trans.
ECh9HVuGW8u40mhZwZc_X9hFi6YYw1O_IXPL2KJj6dkAAGS0k_w7CxHqSZsPgtY8lyquIEta9WcRTTLeg8=w1024-h768-no.jpg
First, need to keep the input shaft from an interference fit with the crank. Quicktime RM199 1/4" bellhousing spacer leaves only a minor amount of contact, and just requires some light clearancing.
78TqVpWSZmuE4rzLG1SLWOl0_4u2iOuJ4vn4B5Jd110OEzuJ-htOc9SGCZVK2VvEtJ_cGYPHH1AKp_UbIg=w1024-h768-no.jpg
Maybe 1/32" of interference remaining.
2TtQ5GiWeutk6kpHHq_zXRROCdzYemvO39dw8ytD9prqWWXiWlQJsL2HrhiSxxN1hSRUAzjjgIsFLP8Jao=w1024-h768-no.jpg
a5X9lHfXUCkKGqujz7LSeUnBu7SMHZl7EiMe7TsQYFJiNwTPeHfk4okynRbVVuBYitInwyOOtfl7fG25Bg=w1024-h768-no.jpg
Next up in the conversion - shifter rail. Here's the shorter TR6060 rail.
11Y3eyvQo5_m1bYeBdULgpq8JFrAKu37y668kru4JKl1j-hZ_gH_AvE_wiPvepGfjBrVJ-oiZA4FU9KeNs=w1024-h768-no.jpg
Two position magnum takeoff.
1XrumSdpwTTGgonvPfEqrGdWfOoauaiTRvGCpKaGiO-ND7NMU4xHZxc7h7Y9yqYkMaUF5Fn2b4vdxDNIIc=w1024-h768-no.jpg
Only thing really remaining to convert is the output shaft and pump mechanism, but it's setup enough for mockup purposes.
Maximum effort shifter cover.
0XHDKtJZgwbRsHUn9QvuDBsNYbOztaI1DdppB1nR0fuhcZGSVQVjwcFujVLf_79YJdcgwckjiHjwVh52vk=w1024-h768-no.jpg
Because a $4.95 stamped steel cover is boring.
Alnh3CA-yj6PX_hlrfvSnEx3ehktAPTOYw24lhHFxYuloP5DScnm9UfEq1ww3Y6wQWNflSg8GxrKfa19-0=w1024-h768-no.jpg
Stabbed.
JgKOgdNPyp4BED7LhGCZLzANlOl_Kdyo5OZ_G_VwPFA6qESd_f0fVUAG45EpsP_dV0iUDhtpYWqw8kJUDs=w1024-h768-no.jpg
Just enough rear angle for the heads to drain.
-DFolQHEsBQlFqClxso0nQfONrj5iOAurqSbnjNUhqGTBBrgQ_0vNtp4r6MGhU2qZvEf7MNJzfCtHwd0MY=w1024-h768-no.jpg
You can clearly see the 5* angle built into the magnum bell and tail housing.
J2N9AVMZv2R2xgtEzIgh1N5cqbn0VUfg-omr_UaNgBYHQO4MIRrvg6msxRM4S9HlH3x6fplqTxCB9EB8BQ=w1024-h768-no.jpg
Engine cradle detail.
_sGuEnGHvZvraA4qIOZpMVqCnuYMKqd9R40u57-xKQ4kJULrdwf4FPBlgZOaGyWHx6nqhND1_O55zmbEYw=w1024-h768-no.jpg
That's about 1" of clearance.
RJYCwAZjiWftBZvBUECLssBghp1SyJHxEk0q_sPgnCzf67fypc_wZ3-sTZzcv9nimvWMjwyg61-Sr-SMQI=w1024-h768-no.jpg
Finally able setup driving position.
dQ-s8DqHe6V0-Y_CYD7vsV8VlNdXFMCV_qN7ExPy5wvcvmGrmFXqAo9513JimutfhMsK6DeQwBUMO6aYjk=w1024-h768-no.jpg
Shifter is exactly in line with the steering wheel - just where I want it - no bent shifters in this muscle car.
v3VhyUWBBaAIbQqGKA2wF4uurjwc5su2TZ5Wt_fhOX-RMVQHnPytnkq6J2uik4bBngwj0rTPQ8V-RitSBw=w1024-h768-no.jpg
Pretty proud of this one - midengine Charger.
jLx6nIj4vGTc20dFwySZe96vJ3-rRuycivXQutPYMEdTHf9cvqhO1B2_Si16FEZlU2XJGkEzO9Bv44Xh3g=w1024-h768-no.jpg
Setup for a flat bottom, with only the oil pan and bellhousing dipping a couple of inches below the rocker beams.
OtuNq6ySitBT4kjbupr7IdPkA568G6rd_DtP-2hZGU9MmBX2m7Y7yx18gSYn5GvTDHMZxnKJ3pUwLqxSEA=w1024-h768-no.jpg
A friend performing driver position duties.
rxN_GZUH4te0J3C0nRmFXzmJC5Dj_grwSpr-qqe2960iDO4WYQ9U8Vc649tQJ8QBMaO6B9P8QRZirIw-qw=w1024-h768-no.jpg
The work continues.
David
Stabbed.
The work continues.
David
I would have had to run it through the gears making engine noises, lol.
Totally did. Like most of us, I’m a grown child.
Yeah....But a GM engine?
There’s a quote from Jim Clark that’s been a favorite of mine. He was asked his thoughts on the Ford-Cosworth engine in his Lotus Type 43, and he replied something along the lines of, “it’s just a tool in a drawer.”
Looks good.
Thank you. Might have a few significant changes, and I’ll keep y’all posted.
David
I thought that the engine in my Daytona stock car project sat back in the chassis, but that GM engine is way way back! My engine is placed in the current location of a modern Nascar car. Mine will be powered by a stroked 472 Hemi engine, the chassis is a modern Loughlin style Nascar chassis. I installed a stock 26 inch b body radiator support because the whole Daytona nose assembly bolts up directly to it. I will still need a radiator shroud that looks like it came from a 1970 Monte Carlo.
Follow Jim Clarks advice and leave that GM tool in a drawer somewhere, and put a real Mopar engine in that Charger.
It’s always amazing that we can swap in Tremec (ie GM) transmissions, GM turbo 400’s, Ford 9” rear ends, aftermarket everything else and nobody says a word, but swap in a LS engine and look out! Lol.
Tremec transmissions come in lots of Mopars, 9" Fords have become an aftermarket item not a Ford part, 400 turbo's :eek: but the engine is the heart:poke:.
That thing is looking wicked, keep it up.:thumbsup:
To see someone build an elaborate Charger with amazing fabrication,and then go with the Generic Motors belly button engine,takes the wind out of the sails on an otherwise cool car!
I'm sure if you guys pooled your money together and flipped him the $20K more that a Mopar crate engine costs he'd gladly take your money and satisfy your requirements!
No ones paying for my Hemi,and anybody that has built one knows what they cost,but I'm not cheaping out on my Charger.
Badass! Love your build and approach. Very cool.
He was expressing a lack of brand preference, but rather one for whatever powertrain performs the required task. It’s an engineer’s approach to design - the glass is neither half empty, or half full. It is twice as large as it needs to be for the volume of liquid.
The LS is ubiquitous, but effective. 330CFM from an unported wedge head is impressive.
Tremec transmissions come in lots of Mopars, 9" Fords have become an aftermarket item not a Ford part, 400 turbo's, but the engine is the heart.
Always appreciate your perspective.
No ones paying for my Hemi,and anybody that has built one knows what they cost, but I'm not cheaping out on my Charger.
Me either. There is no cheap way to do it right.
David
Not everyone wants to shell out the cash to do that assuming they have it in the first place. I can appreciate the fabrication and creativity that goes into a build like this regardless of weather or not I like the engine.
No one has said any negative comments about the fabrication of his car. His fabrication skills far exceed what I am capable of for sure.
Your build has been a major inspiration to me - very clear design aesthetic with a well defined purpose.
Whatever skills I’ve built, I’ve done so in the last 7 years. I’m fortunate to have great mentors, and a handful of of forums from which to draw inspiration. This place has been a big source.
David
